Plant Simulation and process simulate License problem
We have a license for all tecnomatix products. However we are facing issues for license integration with plant simulation and process simulate.
We are attaching the issues snapshot with this. Kindly go through it and waiting for your replies asap.
Re: Plant Simulation and process simulate License problem
Hi Anbu,
for Plant Simulation I can see that you are trying to use Version 10.
Please note that we changed our Tecnomatix license mechanism to the common Siemens PLM license system with Version 11.
So you cannot operate a V10 with a V11 license file.
If this is your problem and you need to use this old version, please contact sales to get a V10 license file.
Ralf
Ralf
Guys I'm gonna purchase a Process Simulate license, but as I checked on the website didn't find any information, it's appreciated you if could give some hints.
