Problem with Tutorial
Tutorial_problem.PNGI am doing my tutorial in Plant simulation 13. I am in section 3 and program says what the capture shows and i cant move on. Could somebody help me with the source code or maybe some other problem. Thank you!
Re: Problem with Tutorial
Hello sharejo,
Just remove the word var in front of the if.
We will fix this in the model.
Thanks for reporting the problem!
Ralf
