Process Designer (Weld and PLP points)
Dear all,
I have a doubt in process designer that is " Can we able to create weld and plp points in process designer or we have to create them in modeling.?"
And what is the use of Varient set Library and what is the concept of varients...?"
So I would like to thank in advance for your support...
Re: Process Designer (Weld and PLP points)
Hello GOLI
I don't see a command to create Weld Points in Process Designer, only in Process Simulate.
I don't know how is your workflow for doing that currently, but you can create a weld point in eMServer using Process Designer by creating a new MfgLibrary object inside a collection object and create a new Weld Point object inside this Mfg Library.
After that you might need to edit manually the properties of the Weld Point, that's why is recommended to use "Import EBOP from File", which imports Weld Points from a specific external file.
Thanks for your kind information
