Querry
I was trying to make a simulation but this error keeps poking up. I see there is nothing wrong with the program but I dont undertand the reason. Any help will be greatly appreciated. Please see the attachment for the program I have written. Thanks Capture11.JPG
Re: Querry
the error message comes from the assembly station, I guess you set up the assembly mode "Attach MUs", in this case the main MU needs to be a container or a transporter (setting of source1). The attached error you can fix by uncheck the new syntax in tools. If you want to create a container on line the commands needs to be:
.MUs.container.create(line);
create is missing
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
