Re-inserting sensors
Siemens Creator
I have a (probably) trivial problem (I hope) in Process Simulate 12.1.3 (fully patched)....
I have created a light sensor, set all of its properties and saved it to its own cojt. At that time I can do everything with it that can be done with sensors (display/hide sensor zone, activate or deactivate it).
Now I delete it and re-insert it into the study. Despite the fact that it still seems to be recognized as sensor (icon in the object tree), none of the sensor relevant operations can be applied anymore. The menu entries are grayed out.
Am I missing something or is this a bug??
thanks and best regards.
