Robot expert to process simulate cell conversion
can i open robot expert cell in process simulate or vice versa?
Re: Robot expert to process simulate cell conversion
No, this is not supported.
RE uses *.cell format.
PS uses *.psz format.
Best regards
Patrick
Thanks @PatrickUnangst
Is there any other way to open cell in PS which is created in RE and vice versa?
No, this is not possible.
If you have a study in PS and you want to bring it into RE you can do the following:
- Display everything in Grpahic Viewer and export as JT.
- Download all your operations with specific robot controller.
- Clone your library.
- In the new library delete all TuneData.xml files.
- In RE define all components from the clone lib and load into a new study.
- Import the before create JT file (Grpahic Viewer)
- Place all your objects. Therefore, use components in JT as reference.
- Do all your attachments/mounts.
- Upload all your operations.
Best regards
Patrick
Thank You @PatrickUnangst
Dhiraj
is it possible to make it from Robcad ?
*.ce file *.psz file?
This is the one of most frequently question asked, i think.
Burpee
Robcad to PS is possible.
Dhiraj
Well, May i know how to do that?
Regards.
Burpee
Please go through the Tecnomatix documentation (help) to acheive this .
ProcessSimulateReferenceManual.chm
OR
Tecnomatix_eMServer_Platform.chm (For latest versions of Tecnomatix)
You may open this help from application itself OR locate it under setup folder of Tecnomatix :
Tecnomatix_12.0_DVD1\Setup\64bit\program files\Tecnomatix\Help
OR
You may also open it it from the help folder available eMPower.
Sections like "Updating eMServer with Legacy Cells" & "Updating eMServer with Robcad Legacy Cell Information" should give you an idea.
The information is available in help.
But it will not be possible for you to use the Robcad Integration unless & until you have the license needed for doing the same.
Dhiraj
Thank you for all the information
Burpee
