Sorter programming error
Sir,
I am doing a project on conveyor system.I'm getting an error in the programming of sorter. I'm using the 11.3 version of the Tecnomatix software.Me and my teammates would really appreciate if you could help us with the programming part.
Thanking you.
Rak**bleep**h
Re: Sorter programming error
Hi RDS1,
in your method sorter2 you are referencing an object with name R1 which just doesn't exist.
Ralf
