Teamcenter alignment
Since a while i'm trying to integrate PS(11.0TR2) in Teamcenter(10.1).
Unfortunately i only found the administration documents:
PS_TC-Admin Guide, Tecnomatix_Process_Simulate_TC_Reference_Manual
but there are no guides to what should be done to align PS to Teamcenter.
How is this alignment done, are there any guides or documents abut this?
Re: Teamcenter alignment
There should be no need to align Tecnomatix version 11 and Teamcneter version 10.1, this is out of the box. The capability to send the data from Teamcenter to Process Simulate is configured through the TEM installer, under the extensions \ manufacturing process planning \ customization for process simulate integration.
