Technomatic Assignment
AssignmentAssignmentProposed SolutionProposed Solution
I was trying to Simulate a bakery on Technomatic. I prepared this overiew of how the process will look like. I am facing following issues.
30 kg of flour enters the system. Should i make it main MU?
I have choosed Customer as secondary MU. Now I want to intoriduce a method which will output different amounts of bread on different days?
Should Dowmaking be  an assembly process?
I would appreciate it if somebody could upload a proposed solution to this problem.
Re: Technomatic Assignment
Honored Contributor
Honored Contributor
- you could use some elements from the fluids library --> deportioner --> mixer --> portioner to model the dough-process
- you could make a delivery list for the flour --> result in different number of breads
- you could use the mixer (fluid element) to model the dough making
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
