Tecnomatix Software merge
Is it possible to merge Tecnomatix models from different software?
e.g. A process from process simulate in a plant simulation model?
Thanks for advance!
Re: Tecnomatix Software merge
not directly, but you can use the data from process designer to make settings in Plant Simulation
(export - import XML)
And you can use teamcenter to select and exchange data.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you for your answer Steffen.
Regards.
