Tecnomatix V10.1 experience, Hick-ups, Crashes, Work arounds.
We are using Tecnomatix V9.1.2.1 and planning to upgrade to V10.1 in the near future.. V9.2.1 has its quirks, hick-ups & crashes and require work around's in some areas.
I am interested to hear what other users experiences are with the V10.1, any surprises?
Re: Tecnomatix V10.1 experience, Hick-ups, Crashes, Work arounds.
Would be great if you could specify the exact application you are using.
Tecnomatix is a family of products for the area of manufacturing planning and contains applications like Process Simulate, Robot Expert, FactorCAD, Plant Simulation, ...
Ralf
We are running Process Designer, Process Simulate, Process Simulate Human, and also have two seats of Siemens Plant SImulation.
