Tecnomatix products Launch errors
I am getting the following error while launching the tecnomatix products.
Request suggestions.
Re: Tecnomatix products Launch errors
See the below pictures for errors.
Process Designer launch error.pngProcess Simulate on Teamcenter launch error.pngProcess Simulate Standalone and Process Simulate Standalone – Teamcenter compatible.png
Hello @AmeyV
Did you start getting these errors recently (new installations) or is your first time launching Process Simulate?
I've already experienced a similar error which was solved setting up database server (where your eMServer is located) DCOM parameter, but this kind of support is more recommended by someone from Siemens.
One thing you can check is if the application can be launched from the eMServer machine and if everything is working fine there. If so, it's probably a communication problem as mention above
