Transform a cable in a flexible cable (Hooks limitation)
Hello experts!
 Is there more than only one way to transform an existing cable (3D converted) in a flexible cable? (to see the behavior of this cable)
 I tried the convencional way using frames and Hooks, however this cable there are a lot of curves and the result is not satisfactory yet.
If hadn't limitation of Hooks, it would be finished, but I can't create Hook near another frame.
Any tip to improve this cable?
Thanks a lot
