Two different PSZ with different libraries on emserver
I had two different studies on emserver. For some reason I took PSZ of each study and started working on it. I modified libraries of these two studies. Product data is also changed and updated on psz.
Now again if I want to update my studies on emserver how shall I do it?
3 REPLIES 3
Re: Two different PSZ with different libraries on emserver
Siemens Legend Siemens Legend
Siemens Legend
Please check Process Simulate online help:
You will have to update each separate library back to the sysroot first. Hopefully, none of the changed items are shared between the 2 PSZ's, then you need to decide which shall be the primary item.
Thank you Ray for the information.
I have one more query. I am getting emserver update failed issue with one of the study.other studies are updating properly.
Please check if you can help me out with attached image.
Siemens Legend
Hi.
You would need to check the eMS.log for a specific error, but that appears like you are trying to update some object in the Project where your user does not have some specific permission granted in the Amin Console/User Administration for that type of data.
Ray
