Unable to import xml file
Dear all,
I am getting a error while i am trying to import xml fiile.
The error is, class type recyclic bin does not exist.
screenshot is attached.
Thanks in advance
4 REPLIES 4
Re: Unable to import xml file
As written in the following discussion, you need to import the customization first!
https://community.plm.automation.siemens.com/t5/General-Tecnomatix-Forum/xml-file-import-error/m-p/4...
Best regards
Patrick
I am getting the same  error while importing customization also.
In the following folder you will find customization for "AssemblyModule".
Please try tom import this customization. It includes the "recycle_bin"
C:\...\Tecnomatix_XX.X.X\eMPower\InitData\AssemblyModuleCust
Best regards
Patrick
Thank you @PatrickUnangst
