Unable to return borrowed license through ROBCAD utility before the expire date
Dear All,
Our customer is using Robacd, when engineers are traveling to project site they are borrowing license through ROBCAD license borrow utility with return date.
If the project completes early they come back and try to return the borrowed license, at that time we are getting following error.
If we analyze the error logs it shows: lmborrow: Error, borrowed license doesn't match any known server license. (-128,595)
We have created IR for the same even after following steps suggested by them we are not able to find solution. Finally the same IR was converted into PR but no updates on the same since long time.
Please suggest a solution
Thanks in advance
Best Regards,
Jeethan Rohan
Re: Unable to return borrowed license through ROBCAD utility before the expire date
Dear Experts,
Please suggest some solution or workarounds.
Best Regards,
Jeethan Rohan
