Update all objects in drawing FAILS
Has anyone experienced issues in FactoryCAD when Comparing drawing with Library Items. Specifically with updating all objects in drawing to current library. I've seen instances in which not all object within the drawing are updated (after having selected Update all objects in drawing) to match the changes made to the library items. If so, how can this be fixed?
I've also seen at times that when this occurs, pulling an object from the library will have the new updates(makes sense, since they're pulling directly from the library) but the old objects still in the drawing still have old/outdated information in them(despite just having run the "compare drawing with library items and running the update all objects in drawing).
