Why i con't log in TX in my Vurtual machine?
When i type in my acount and password in my TX and press 'Enter', a dialog box popup says 'some viewer control bar IDs are not unique.The affected viewers might not work correctly.Please consider deleting the user configuration file'.After this TX get crashed.
Re: Why i con't log in TX in my Vurtual machine?
You can try to run "Tools - Reset Current User Settings" in Tecnomatix Doctor.
Or alternatively delete folders from %USERPROFILE%\AppData\Local\Tecnomatix
Regards, Vladimir.
