XML file import error
Dear all,
Please help me in this i am importing xml file i am getting below error.
Thanks in advance.
Re: XML file import error
Hello @Dhiraj44
It looks like you're trying to import a project object inside another project, which is returning you an error, because you can't do that.
If you're trying to import all the contents from one project into another, you may want to export xmls for the first child nodes of your project folder and import then into another project. You can also put all the contents in a collection and export/import this collection xml inside your new project.
Thanks a lot.
