can a FactoryCAD 12.0.6 drawing be opened with FactoryCAD 12.0.4 without problems
Not applicable
If I update to FactoryCAD 12.0.6 and save my dwg files with this point release, will
there be a problem when these dwg files will be opened with FactoryCAD 12.0.4?
Re: can a FactoryCAD 12.0.6 drawing be opened with FactoryCAD 12.0.4 without problems
Not applicable
Hello Ralf
We typically try to maintain dwg compatibility within a major release, in this case
v12. Therefore dwg files saved in v12.0.6 should open in v12.0.4.
However, if you have a 12.0.6 dwg file(s) that does not open in 12.0.4, please let
us know as soon as possible.
Deepak
>will
