doubts in process simulate
how to do object flow operation after welding two parts. i welded two parts after i did object flow operation but only one object is moving. how to do flow both object.IMG_20180118_172710.jpg
Re: doubts in process simulate
You should have an assembly. Therefore create e.g Compound Part as parent for your two parts.
After both parts connected just use the compound part in your object flow.
This will include both parts.
Best regards
Patrick
thank you @PatrickUnangst.
sir say the steps for assembly for make it as single component.
in Object Tree select the "Part" node.
Create a new Compound Part.
Select your two single parts, drag&drop onto the Compound Part.
In your FlowOp now select the CompoundPart as object.
Best regards
Patrick
its working.
Thank you sir @ PatrickUnangst
