emserver update failed due to current import restriction settings
Hi all,
I am getting this error after updating psz file on emserver. Thanks in advance
PFA
Re: emserver update failed due to current import restriction settings
Siemens Legend Siemens Legend
Siemens Legend
Hi.
Please check with your eM-Server Administrator whether your eMS user has the required privileges. Add them if missing.
Check the Tecnomatix Administration online help, Access Control Tab, for the list of all Pivileges. Compare if your user needs added privilege.
Ray
