how to import and export weld points in robcad?
Hi all,
I am trying to import weld points but i am unable to do that. Also i want to export weld points but i can't see option of exporting weld points.
Dhiraj
6 REPLIES 6
Betreff: how to import and export weld points in robcad?
Hi!
You can import weld points in the Weld_locs menu - see picture.
There is no export function for weld points in Robcad.
But you can "export" the weld locations by using Query->Location information for instance.
Re: how to import and export weld points in robcad?
First you have to export the points from your cad system in AutoCad file then convert that file into .co file.
After that you will be able to import it.
Simply do one thing, if you have co-ordinates of weld points then make .pt file and then import.
POINT Name X Y Z
Make it in notepad, save it, change extension to .pt & then Import.
@ export - No option
Another way is to write all the point information (name, x, y, z) in a robface file (*.rf) and import that file.
The advantage from this approach is that you have the point cloud in a component.
Hello
I'm new to this robCAD
i want to load One JT file in Siemens NX
and then i have created one folder with name of pract.co, inside i have pasted that JT file
When im trying to Get Component in the cell it is not taking .it is showing error.
pls help me to how to load parts
Robcad does not work with jt files, only with .ce (cells) and .co (component).
You have to convert your jt file in .co or robface
