login failed. unknown exception.
hello guys,
I am facing problem while log in process simulate. Process simulate was working fine till yesterday. suddenly because of electricity cut, system shut down. now it is showing this error
Please help me for this.
Dhiraj
Re: login failed. unknown exception.
If it is client system and EM server is in different system then try the following
1) Try pinging EM server from the client machine.
2) Check in host file for the EM server IP.
3) Clear temp files and try to login.
Best Regards,
Jeethan Rohan
Best Regards,
Jeethan Rohan
Problem is solved ?
If not and if you are getting same error please feel free to contact.
Best Regards,
Jeethan Rohan
