xml file import error
Dear all,
I am importing xml file but i am getting a error. please suggest the solution.
I am attaching the screenshot.
class type recycle_bin does not exist. please customization.
4 REPLIES 4
Re: xml file import error
The problem is, the customization from the project you are trying to import, doesn´t fit to the customization which is currently loaded in your Schema.
Import the correct customization first using "Import -> Customization". Therefore close all project before and close all open sessions in Admin Console.
Best regards
Patrick
Thanks PatrickUnangst,
where can i find correct customization file?
Customization is connected to the DB Schema which includes your project you have exported.
Best regards
Patrick
Thanks a lot @PatrickUnangst
