Entry Point Not Found
When I debug one of the examples, the "Entry Point Not Found" errors prompts. How can I do with it?
QQ截图20160529102825.jpgthe error message
Re: Entry Point Not Found
Try using http://www.dependencywalker.com/ depends.exe on the built executable or the jttk80.dll and see what's going on.
Some DLLs might be missing or a X86 X64 DLLs mix conflict.
Does it happen when the program loads or at a particular line (load library ? GetProcAdress ?)
Nicolas
I too had the same issue.
I have tried by changing the Active Solution Platform in VS2012 configuration manager, to Win32, and it worked.
Gowreeswar
