How to Load JT using Java
Hi Expert,
I want to load JT in my program and create a 3D PDF file using Java. Does Siemens have any solution for this? Thanks
Re: How to Load JT using Java
Siemens Legend Siemens Legend
Siemens Legend
The JT Toolkit does not currently have support for working with Javascript. Depending on what you are after there may be some capabilities for you in the PLM Vis toolkit. This is a licensed offering targetting viewer application development.
Mike Z
