How to embed/add JT viewer in dot net application?
I have created user interface using WPF. I would like to add JT viewer to my user interface so that I can open JT files within my application.
Is there ant way to add JT viewer in custom application ?
Is JT Open Toolkit has functionality to create your own JT viewer ?
Re: How to embed/add JT viewer in dot net application?
Siemens Genius Siemens Genius
Siemens Genius
The JT Toolkit does not offer API that will directly enable creating a JT viewer. You can use the toolkit to read the renderable content from JT into your viewing application though.
Siemens PLM does offer at toolkit called PLM Vis that will enable creation of JT viewers. Have a look on the website
http://www.plm.automation.siemens.com/en/products/open/vis/index.shtml
Mike Z
Mike, Thank you for the information. I will check the link you have given.
- Sachin
