How to map tessellation to topological entity?
I tessellate JTBrep and then I need to find out the trisets that corresponds to each JtkFace and JtkEdge.
How do I build the association between tessellated JTBrep and JtkFace/JtkEdge?
I tried the methods given in JT document. But still I'm unable to get the tessellations associated with those JtkFace/JtkEdge ?
Any suggestions on the workflow?
Re: How to map tessellation to topological entity?
Siemens Legend Siemens Legend
Siemens Legend
What version of JT Open Toolkit are you working with?  Are you able to use XT B-Rep?
Check section 7.1 in the docs, Topological Facetted Data
Mike Z
