How to repair a crashed vfz file
Hi All:
My vfz file looks crashed. it cannot be opened in TcVis. The error is "Failed to open document". Is there any utility from Siemeans to fix it?
Thanks.
Re: How to repair a crashed vfz file
Siemens Genius Siemens Genius
Siemens Genius
Make sure the JT files used in the saved session are accessable when you attempt to open the .vfz. Depending on how you saved it there could be links to the JT content.
Mike Z
