JT Open Toolkit can able to attach JT file into 2D PDF file
I already posted same post in JT2GO to check for any command line utility can address my requirement.
I am just checking the same can be able to do in JT Open Toolkit with API. I downloaded the trail version of JT Open toolkit, i do not see any API which able to perform mentioned in subject of the post.
Did any one tried in similar lines?
regards,
kishore
Re: JT Open Toolkit can able to attach JT file into 2D PDF file
Siemens Legend Siemens Legend
Siemens Legend
Hi Kishore,
There is not an API in JTTK that will attache a JT file to a .pdf. This is provided as an interactive feature or JT2Go only at this time.
Mike Z
