JTInfo settings for CAD property display
Siemens Legend Siemens Legend
Siemens Legend
The JT Utilitiy "JTInfo" does not list CAD properites such as CAD_DENSITY, CAD_MASS, and CAD_MATERIAL by default. If you want to see these properties in the full list output you need to make this setting in your CMD window
set JTK_CAD_PROPERTIES_ENABLED=0
The same is true for layer properties, to see them
set JTK_LAYER_MANAGER_DISABLE=0
This is a deficiency in the current JTInfo documentation at a minimum.
Mike Z
