Leaf node property
Hello, I would like to know whether it is possible to control the visibility of nodes in JT via leaf nodes. By this I mean that when opening a file certain leaf nodes are not hooked. Is it possible to hide individual nodes with the JT Toolkit? Is stored in the JT file anywhere, whether a node is hooked or not?
I would like to know if it is possible
Two questions:
1. Is it possible in the API to find a node by a property key?
2. Where is the information stored (leaf node hooked or not) in a .Jt file?
Thanks in advance!
Re: Leaf node property
Siemens Legend Siemens Legend
Siemens Legend
JT Toolkit looks at JT files hierarchically through product structure. You can likely do what you are after using the JtkHierarchy class although I am not sure what you mean by a property key in your text below.
Mike Z
