PLMXML Example fails with Load Error
I am trying to run the PLMXML example and am receiving the following messages:
Export license found.
Import license found.
Load Error: Licensing error: SDK is not licensed
Missing Adapter (JT), resolving: MODEL$_XML4.jt
Unable to load: "MODEL$_XML4.jt"
The plmxmlSDK.dll, plmxmlSDL.lib, and  plmxmlAdapterJT60.dll files all exist.
What am I missing here?
Thanks for your time and help.
Re: PLMXML Example fails with Load Error
Siemens Genius Siemens Genius
Siemens Genius
This ended up being an environment issue, check the other post on this topic for resolution
Mike Z
