Read Layer ID
Hi, I would like to know if it is possible to read out the layer ID of individual nodes. For example, there is a separate layer for each leaf node and I would like to know the layer ID of the leaf nodes. I have tried it with the JT Utilities, with the function "jtinfo" but could not found the info.
Thank you and best regards
Frobless
Re: Read Layer ID
Siemens Legend Siemens Legend
Siemens Legend
Sounds like you are loolking for a utility that shows this, I don't know of one. This is possible witht he JT Toolkit API., Check section 9.1, Layer Management
Mike Z
