Traversing entities in a JT File - Joint Nodes
i have a Jt File with kinematics inside. I could find a property node with the kinematic model of the device, it has references to other entities in the assembly (id's to parts - links, id's to pmi items acting as frames) but I couldn't find the referenced joints (ids are known) in the Hierarchy of the jt file nor assiosiated PMIs.
Till now I could traverse all JtkHierarchy items in the root of the "importer" and all assosioted "pmi's" without luck.
Two questions:
1. Is it possible in the API to find a node by a property key?
2. Where is the information stored (joint definitions) in a .Jt file?
What is JT?
JT is the World’s Most Widely Used 3D File Format for PLM
JT is the common language of PLM and is the world’s most widely used 3D format. JT is the first ISO International Standard ( IS 14306-1) for 3D visualization and collaboration. Compact and accurate, JT is used throughout the product development lifecycle in all major industries to communicate the critical design information typically locked up inside a CAD file.
Siemens PLM Software customers rely on JT to be the most robust 3D visualization format available.
JT Open Factsheet
JT Open Member Resources
JT Open Documentation Technology
JT Open File Format Technology
JT Open Toolkit
Downloadable viewers for Windows Desktop, Windows 10 Universal App, Android and iOS.
Download JT2Go for your platform today Download JT2Go Desktop 64 Bit all languages
Download JT2Go Desktop 32 Bit for English
Windows 10 JT2Go Universal App
Android JT2Go
iOS JT2Go
