Visualization of .JT File
I want to be able to display a JT file - prefereably using OpenGL. I can use the JTOpenToolkit to read the contents but then how do I display this contents - like JT2Go? The reason is that I want to superimpose my data on top of the JT CAD data
All suggestions welcomed
Re: Visualization of .JT File
Siemens Genius Siemens Genius
Siemens Genius
As you noted JT Open Toolkit is a read/write toolkit for JT content. To build viewing tools you will need an SDK with rendering features. Siemens PLM does offer a product call PLM Vis that support that type of application devleopment. You can find more informaiton on our website
http://www.plm.automation.siemens.com/en/products/open/vis/index.shtml
Mike Z
