Why part color cannot be edited after running the script
 After I changed the part color by using the script, the part color cannot be changed any more interactively neither in VisMockup or with the code. Seems the color is locked after assigning the material. Any help to solve this? below is the code I used to assign the color.
param (
[double]$R,
[double]$G,
[double]$B
$VisObj = New-Object -ComObject VFFrame.Application
$VisApp = [System.__ComObject].InvokeMember("VisAppAutomation", [System.Reflection.BindingFlags]::GetProperty, $null, $VisObj, $null)
$material = $VisApp.ActiveView.RootNode.BasicMaterial
$material.Ambient.Red = $R
$material.Ambient.Green = $G
$material.Ambient.Blue = $B
$material.Diffuse.Red = $R
$material.Diffuse.Green = $G
$material.Diffuse.Blue = $B
$VisApp.ActiveView.RootNode.BasicMaterial = $material
Thank you.
David
Re: Why part color cannot be edited after running the script
Siemens Genius Siemens Genius
Siemens Genius
Not sure what is going on here but I am not aware of any JT file setting that locks color in a JT file. Suspect this is an application level setting
Mike Z
