Assemblies in JT2GO
I'm new with JT2GO and when I try to open an assembly it seems to open only the assembly file. I don't see any of the components.
Thank you
Thank you for your reply
Eric Ferland
NX10 user
Re: Assemblies in JT2GO
Siemens Legend Siemens Legend
Siemens Legend
If the Workspace window tree tab shows a Box with a gray check and expanding the structure shows Red X's in it, then you don't have the assembly jt set up correctly.  If your assembly is named "MyAssembly", then there will be a MyAssembly.jt and then a MyAssembly directory (at the same location as the .jt file) that contains the jt components of the assembly.
If gray check and red X's are not present in the tree, did you try RMB in the viewer and doing an "All On" or checking the top level box of the assembly in the tree?
Rick
I'm not sure I understand what you are trying to explain, but here's a screen shot of my JT2GOjt2go.PNG
Thank you
Eric Ferland
NX10 user
Siemens Legend
That is interesting.
Can you 7-zip the Jt assembly and send it to me, so I can try loading it myself?
Rick
I will send you something on monday.
Thanks a lot for helping!
Eric Ferland
NX10 user
I found the problem, it was the export JT options that were not set-up properly.
Eric Ferland
NX10 user
Could you mention the incorrect and correct export settings for anyone finding this topic in the future?
Kind regards,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
Unfortunately, I can't tell what the wrong settings are, since the JT files are generated automatically everytime I save, an this was configured by our NX team, which is in another country.
I generated the Jt files manually with the default settings, and it worked fine.
Eric Ferland
NX10 user
