Cannot execute Jt2Go_Acrobat_Reader_Plugin.exe
I try to install Jt2Go_Acrobat_Reader_Plugin.exe, but it stops with the following error message.
My Adobe Acrobat Reader version is the following.
Adobe settings for viewing JT2Go URIs.pdf refers to Acrobat Reader 11.x and DC, but README.txt only refers to
  Acrobat Reader support;
  Versions 11.0 and newer
Is the above acrobat version supported or not ?
Re: Cannot execute Jt2Go_Acrobat_Reader_Plugin.exe
Siemens Legend Siemens Legend
Siemens Legend
It is for Reade only.  Reader must be installed for it to work.
Rick
Thank you for your reply, RickV.
I understood the specification at this moment.
