Color difference between solidedge and JT
Hello Everyone,
I exported the model from solidedge ST8 to a JT model, But the color seems not.
Those two parts are the same, from one assembly. What is the reason?
thank you in advance!
Re: Color difference between solidedge and JT
Siemens Legend Siemens Legend
Siemens Legend
Hi Hunter,
Can you provide some additional information.
What version of SolidEdge ST8 do you have, specifically - ST8 OOB or patched to an MP, like MP6, MP7, etc?
What version of JT2Go are you using?
What version of JT file did you export your data as?
Is it possible for you to provide the JT file(s) for me to look into?
Rick
Hi Rick
Thank you for you reply.
I'm using ST8 MP7 and JT2GO 10.1.5
See export setting below:
Hunter
didn't know how to upload the model...
Hi Rick
Here is the JT file.
thanks
Hunter
Hello
I have tried this with one part, and I found if I give one part a color and another one with none or part style, then the one without color shows gray...if I give all parts color, it shows correctly, or if I don't give them color, it also shows correctly.
Is it true about JT2GO???
Thanks and regards
Hunter
Siemens Legend
Thanks Hunter,
My guess is, that there may be a problem with the translator that is exporting the data out of SolidEdge.  I tested the files you gave me in JT2Go 10.1.5 and 11.2.2 and also in Teamcenter Visualization 10.1 (which JT2Go 10.1.x is based on).  The files all show up as you have described.  I would send all of the information you have posted here to the SolidEdge team to see if they can provide guidance on what you are seeing.  I do not believe the problem is with the viewing solution, but in how it is being exported out of SolidEdge.
Rick
