Error message when opening file on iOS App via "Open In"
When the app opens a file via "Open In" successfully, I often get an error message that says:
index.html (Failed to load PMI Data.)
Re: Error message when opening file on iOS App via "Open In"
Siemens Legend Siemens Legend
Siemens Legend
Again - would you be able to share the data which exhibits this problem?
Rick
attached to this reply ==>
ALSO, the uploader won't let you upload a JT file, but it will let you upload a DWG file? Ya'll need a JT file mime type set up on this server Smiley Happy
