Facory Cad JT Importing
Hello All,
I am using Factory Cad14.0. I have JT files converted from Robcad. When I Import the JT files using IND command in Factory. 3D file is getting loaded and Top view is missing(Only Rectangular box is visible).Can anyone help me to solve this issue.
Re: Facory Cad JT Importing
Siemens Legend Siemens Legend
Siemens Legend
So,
You are seeing issues when loading the converted JT file into Factory?
If that is the case, the question below sounds like a translator issue and should be posted elsewhere.  Maybe the JT Open Toolkit forum?  This forum is for JT2Go and it doesn't sound like you are using it.
Rick
