How to generate Html file automatically?
Hi.
Is there a way to generate a html file automatically? Just like using windows command line or batch?
Re: How to generate Html file automatically?
Siemens Legend Siemens Legend
Siemens Legend
Generation of HTML files is only available through the UI, there is no command line or batch option for this.
Rick
Hi
Ok. Thanks very much!
BTW, Can PLM export JT file as a html?
@RickV wrote:
Rick
Gears Legend Gears Legend
Gears Legend
It was possible with JT2Go versions before 11.3 to start direct the integrated JTToHTML.exe in folder program. With this exe it is possible to generate a html file.
Best Regards
Wolfgang
Siemens Legend
Yes, it was possible before 11.3. The ability to use the .exe was removed in 11.3, as it is not a standalone feature - it must be used through the UI.
Rick
Will this possibility to make this JT to HTML conversion in batch come back sometime in the future? Thanks in advance for any information about this.
Siemens Legend
There are no plans to expose batch generation of html files.  This is a program management decision.
Rick
