JT2GO 11.2 64bit Load parts on open
Does anyone know how to stop all parts in the assembly from being turned on when you open the assembly? In the older version there was a way to stop this from happening and it allowed large assembly files to be opened faster and take up less of your Ram so that you could only turn on what you wanted to.
Re: JT2GO 11.2 64bit Load parts on open
Smiley Happy
have found it. One is not working. But an other way does run.
All bars are now a bit mixed, it is not so clean like desktop version 10.1.5.
Hope this help a bit.
Best regards
Teddy
We have tried those options, but either way, rather that is checked or unchecked they all still load turned on.
Well, have test it here again it works.
You use the English version too?
I try it now in the German version... a moment please.
Same, here it works.
To explain, have seen some buttons are different between the language versions.
Next Test done, have found out again JT2Go crash if you try to open an TC-"VFZ"-File with True Shading Render (loaded parts on or off does not matter) he try to open the texture (if you give or not) later he crash.
Siemens Genius Siemens Genius
Siemens Genius
The issue with Loaded Parts On not working is a known bug in the 11.2 release. This will be resolved with the next release.
Mike Z
Siemens Genius
can you share your .vfz file?
Mike Z
