JT2GO & IOS Update
The app updated on both my iPad & iphone but neither will show an icon to "open with" from either an e-mail or from dropbox.  The "load" tool is weid as there no location to load from on ios, correct?  What is needed to show the JT 2 go icon so i can "open with" ?  I've deleted an reloaded app but still no icon.
-Craig
Re: JT2GO & IOS Update
Siemens Legend Siemens Legend
Siemens Legend
Thanks for the feedback.  At this time, you need to use iTunes to add the jt files to the JT2Go app.
We are looking into this issue.
Rick
Maybe I'm a bit confused here..
So for me to share a JT file with my customer they need to save a JT file to a laptop with itunes and then sync it?  No go if so. Now my customer need to sync to a laptop or PC just to get the files?
-Craig
Siemens Legend
As I stated, we are investigating.  We are making progress toward fixing this issue.
Rick
Is there a way to use or get the older rev of JT2GO app. I cant get the new rev to work properly, its sluggish or wont load, and its much more complicated to use. With the original rev I could click on a part and the tree structure would go right to it, I could turn it off or go up the tree and turn off the assembly. I want the old one back
Siemens Legend
Sorry for not replying sooner.  We updated the app a few weeks ago (hopefully you were notified) - it will now handle file associations.  Note - there are some services that do not support the file associations, like Google Drive.
Siemens Legend
We are unable to re-post version 1.0 of the app.
I do have a couple of questions.
What type of device are you using?
What size files are you trying to load and do you know what version of Jt they are?
Any chance that you could send us one of your files that you are having problems with?
The Help (from the settings dialog) does contain verbage on how to navigate the structure using the structure dialog.
Glad the ios app got updated!  I do wish I was notified though, (almost bought E-drawings on my PC so I could export a model and be able to see a model tree)
I have a dropbox folder I share with each customer so everyone can access JT's from devices. Works on my 6s iphone with ios 10, I'll have to check ipad when I'm home.
Thanks, Craig
-Craig
