JT2Go 11.2.2. How can I change the DPI-Resolution Setting when generating a PDF from JT:
I generated a PDF from some Model Views (>30 Modelviews) in a Model. When I zoom the Model in PDF, I couldn’t read the PMI correctly (Raster Picture)
How can I change the DPI-Setting in JT2Go so that I can get a picture resolution of factor 2?
Best Regards
