JT2Go IOS version PMI support
Hi all,
I have read on the internet that the IOS version (which is old ans seems not been supported by developper) does not provide the PMI support.
Customer need this functionaly ! Is there a plan to imporve the IOS programe in this way ? Did someone knew an alternatively solution ?
Thank you in advance !
Re: JT2Go IOS version PMI support
Siemens Genius Siemens Genius
Siemens Genius
There are plans for an iOS version of JT2Go that will display PMI. New versions for iOS and Android will provide feature parity with the JT2Go for Windows 10 Universal app version. The new version for iOS will  be available shortly.
Mike Z
Hi Mike,
That is a very good news. And you probably can imagine my next question :
Can you tell me an aprrox date of release ?
Thx
Sebastien F
Siemens Legend Siemens Legend
Siemens Legend
Target release date is 31 May 2016.
many thanks for your answer
Siemens Legend
JT2Go for IOS was released on 30 June 2016 to the Apple Store.  Please read the description of the app, which provides information about some limitations.  Also - JT files must be added to JT2Go via iTunes.  File associations (MIME) are not possible at this time.
Rick
Hi Rick
Thank you for quick update
I will give it try I soon as I can.
Is there a way to use or get the older rev of JT2GO app. I cant get the new rev to work properly, its sluggish or wont load, and its much more complicated to use. With the original rev I could click on a part and the tree structure would go right to it, I could turn it off or go up the tree and turn off the assembly. I want the old one back
