JT2Go - IPAD2 - ST4
Not applicable
the JT files generated in Solid Edge ST4 are compatible with this app?
Re: JT2Go - IPAD2 - ST4
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
JT is a standard, so there's no reason they should not be compatible. However JT2Go for iOS is limited to opening single JT files, and is also limited in the size of files it can open since the memory on iOS devices is limited.
Steve Menyhart
