JT2Go change interface language
Hi!
I'm installing latest JT2Go 11.2.2 on clients but some clients want German language interface.
In installation I select German but later I don't see option to change to German.
Does interface language depend on operating system language?
Regards!
Re: JT2Go change interface language
Siemens Legend Siemens Legend
Siemens Legend
The application will use the OS settings to determine what language to use, so yes - once you install (selecting to install German), you must also set the OS to German.  JT2Go will default to English if the OS does not match one of the languages that you installed JT2Go with.
Rick
